Discussion topic: Q Box disconnecting from Sky WiFi
Message posted on 10 Nov 2025 02:08 PM
Since Sunday the 6th of December, my Q box has disconnected from the Sky WiFi. I've done all kinds of resets. When it does connect, it lasts less than 5 minutes. Regular Sky TV has no issues, all my other devices work perfectly fine and I'm at a loss. I've even used the "Hidden Menu" to reset all of the settings. Any helpful suggestions are welcome!
Message posted on 10 Nov 2025 02:10 PM
Re: Q Box disconnecting from Sky WiFi
I'm not sure that date is correct.
Message posted on 10 Nov 2025 02:41 PM
My apologies everyone. Since 6th 9f November! Thanks for pointing out that glaring error mate
Message posted on 10 Nov 2025 02:44 PM
Sorry! Sunday the 6th of November. Cheers mate
Message posted on 10 Nov 2025 02:46 PM
6th November was last Thursday.
Message posted on 10 Nov 2025 03:07 PM
OK. I apologise. The exact date and time after rechecking was 11:31pm on Sunday the 2nd of Nov
Message posted on 10 Nov 2025 03:19 PM
Hi @Shaun+gomes
Assume you have completed the following ?
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 10 Nov 2025 03:28 PM
Hi there! Yes, I've spent the past week doing all of the resets advised by other people who were previously affected by similar issues. I really appreciate your reply
Message posted on 10 Nov 2025 03:35 PM
I assume that included a Network reset? @Shaun+gomes
The Reset settings in the hidden menu does not reset the Network.
Which Sky Router do you have?
Message posted on 10 Nov 2025 05:14 PM
The model number is SR213-02-UK-wht.
Message posted on 10 Nov 2025 05:34 PM
Yes @Shaun+gomes
That is the Sky Max hub and should be connected to your Q box by using a Network reset and entering the SSID and password for the router 2.4 Ghz band.
Message posted on 10 Nov 2025 06:15 PM
Thanks mate. I'll give it ago and let you know how I get on!
Message posted on 11 Nov 2025 06:57 PM
It didn't work. I tried several time. It looks like I'm going to have to call the Sky Troops in....
Message posted on 16 Nov 2025 08:40 AM
I've had the same issue too recently, and like you have tried resetting everything and still not found a solution. Did you manage to fix it in the end and if so how?
