Discussion topic: Purchases unavailable
This message was authored by: RKB1977
My sky purchases are unavailable.
getting error ' to see your purchases you must be connected to broadband check settings'
i have done this and I am using broadband for Netflix, you laptop and computer etc
I've done the on off stuff at the plug
anyone else having this issue
Re: Purchases unavailable
Hi @RKB1977
Are you using your Q box for Netflix or another device?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
