Discussion topic: Programmes unable to record
Message posted on 19 Aug 2026 09:55 PM
The programmes I have recorded are not showing under recordings and new programmes I am trying to tape state that they can't be recorded. Has anybody else experienced this?
Message posted on 19 Aug 2026 10:03 PM
Re: Programmes unable to record
Hi @Jacqui1804
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
