Discussion topic: Programmes keep recording at 2am with signlanguage
This message was authored by: Kks
Series link keeps  finding the late night repeat of something and recording that instead. It doesn't matter how often you delete the series link and re-add it on the 7pm mainstream showing, SkyQ will series link the 2am repeat version instead. This  means that some  recordings are now shown in a half-size frame with sign language  which is not what I want.
Can anyone help?
Re: Programmes keep recording at 2am with signlanguage
Can anyone help?
@Kks you will need to report this to viewers relations at [email protected]  the problem will be that the broadcaster is responsible for adding the links and they are adding them wrongly
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Can anyone help?
hi @Kks
Seriies Links are set up according to the provider. If you think they are wrong for a programme then best to  email Viewer Relations : [email protected] making sure you mention what Programme, which channel & any specific times
Of course the work around is not to rely on the Series Link and search the TV Guide for the showings  at  normal times & set them manually (any with Sign Language should be marked with an SL logo)
