Discussion topic: Programme Unavailable
This message was authored by Looby0498 This message was authored by: Looby0498
Same problem as many others, sky q mini box showing programme unavailable - no programmers are available, the main box working fine and the mini box shows everything as connected and confirms I have multiscreen. Another message has appeared saying I might not have the correct subscriptions. Carried out all the usual shutdowns of all devices and routers and the problem persists. Please can this be escalated.
Re: Programme Unavailable
Hi @Looby0498
Try a Reset Settings in the main  Q box hidden menu.
