Discussion topic: Problems with remote
Message posted on 24 Nov 2023 07:25 PM
Remote will turn tv on and off and turn volume up and down but won't change channels
Message posted on 24 Nov 2023 07:45 PM
Re: Problems with remote
Hi @DH31
The Sky Q remotes when correctly paired to a TV will only work Volume, Mute, On/Off and input select. They will not change channels on the TV Set.
If you are saying it will not change the channels on the Q box then it possibly needs resetting.
To completly reset your Bluetooth remote.
