Discussion topic: Problems with remote and tv
Message posted on 28 Aug 2026 08:01 PM
My Sky Q remote works perfectly for the Sky box, but it intermittently loses TV power and volume control. I've replaced the remote and the problem remains. Restarting the Sky Q box restores the functions for a few days, then they stop again. The problem started after my Sky router was replaced."
Message posted on 28 Aug 2026 08:11 PM
Re: Problems with remote and tv
hi @Paulbj1968
Neither the SKY Q box nor the router should have any effect on your remote's ability to control the TV once it is set, despite the fact that restarting your box seems to coincide with it working again.
The SKY Q remote just uses Infrared codes to operate the TV just like your TV's own remote
Is the TV's IR receiver clean & not obstructed.
When it plays up can you try your TV's own remote to see if that also suffers
Message posted on 28 Aug 2026 08:19 PM
Hello,
Nothing obstructs the box and it's clean. The remote for my tv hasn't controlled it, but it is currently working. Still no control of volume or power through sky remote though. Very frustrating!!
Message posted on 02 Sep 2026 12:20 PM
I keep putting in new batteries and they only last 3 days
Message posted on 02 Sep 2026 01:42 PM
I had the same problem of not being able to turn off the tv and volume again last night!!
