Discussion topic: Problems with mini box
This message was authored by: Haydenharrod
My mini box is frozen , it keeps losing virgin fibre optic broadband , and will not reboot even when I unplug it and try to reboot it
Re: Problems with mini box
Hi @Haydenharrod
Q mini boxes connect to the WiFi from the main Q box and not your Network WiFi.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
