Discussion topic: Problems with catch up, recordings and mini box
Message posted on 11 Jul 2023 06:26 PM
We cannot watch any recordings or catch up, says there is a technical fault with this channel. Also very slow when changing channels and our mini box in another room is not working. All boxes are ticked in regards connections and mini box.
We rebooted the hard drive, turned the whole system off for a few minutes including the router.
many other suggestions?
Message posted on 11 Jul 2023 06:29 PM
Re: Problems with catch up, recordings and mini box
Try a Reset Settings in the main Q box hidden menu.
Message posted on 11 Jul 2023 09:22 PM
Tried all of this and still not working.
also showing 'there is a technical fault with this channel' on most channels
Message posted on 11 Jul 2023 09:28 PM
Check the following link
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
