Discussion topic: Problems with UDrama
This message was authored by: JohnCTimperley
When I try to download a UDrama program it tells me I do not have a subscription. I am on Signature and can watch UDrama without a problem.
Re: Problems with UDrama
I believe you need an HD subscription to do that.  (Unless there's a SD download)
Avatar for JohnCTimperley
Thanks. How do  I find an SD download?
hi @JohnCTimperley  you can select 'Other formats' but I think that can be a hit & miss.
Best to set the Download Preference in :
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
I am actually set to HD in preferences
Yes that is the default - if you don;t have the HD add on it is best to set it to SD
I only have HD and UHD available
hmm - probably worth doing a full power down (switch off at mains / unplug) restart
Been there done that 🙂
What are you trying to watch?
Can't you just stream it in the U app?
Was my post helpful or informative to you? Please give it a thumbs up/like.
If my post has solved your problem, great! Please click on "Mark as Answer" under it and share the love!
Yes, that does work,  but is  pain and I pay a lot for my Sky subscription.
