Discussion topic: Problems applying to Join Sky on line
This message was authored by: timboHuge
i have been referred to join sky by a friend. ive been on sky website but there is nowhere to select to apply for sky q. is it not possible to join on line?
Re: Problems applying to Join Sky on line
Try https://www.sky.com/tv/sky-q?irct=glassHome-qUpsell
Avatar for timboHuge
Thanks GD1, I've used the linl but when I press on "get started" it reverts me to a page that says "
Unfortunately we can't process your request online right now
Please try again later or alternatively view the status of your account.
Manage my account
I suppose I will have to call them. Their website isnt very easy for new customers to join!!
Hi @timboHuge
See if this link is any different
https://www.sky.com/deals/tv?irct=timeouterrorcta-uk
Yeah that didn't work for me
try this one
If you are using your friends referral link then you do need to make sure you click through it to place the order otherwise it is likely that the referral will not work.
