Discussion topic: Problem with sky q box
This message was authored by: Jeanie
The sky Q box keeps switching it's self off then I need to re
b it before I can get up and running again
Re: Problem with sky q box
Hi @Jeanie
Check your Standby settings.
In Eco the Q box goes to sleep in the early hours.
Also in Eco and Active it will go into Standby after a period of inactivity.
https://www.sky.com/help/articles/using-the-standby-settings#:~:text=Changing%20the%20standby%20sett...
If the issue continues
Avatar for Jeanie
Thank you for getting back to me, I have an engineer coming out to me tomorrow to see if the problem can be fixed.
