Discussion topic: Problem with mini box
Message posted on 12 Apr 2026 12:31 PM
My tv is displaying Error :MR102
Message posted on 12 Apr 2026 01:19 PM
Re: Problem with mini box
@Chuck111
If you haven’t done it already it may be worth rebooting the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
