Discussion topic: Problem with hard drive on Sky Q.
Message posted on 23 Aug 2024 10:48 AM
Message on TV stating cannot record, problem with hard drive.
Please advise
Message posted on 23 Aug 2024 10:55 AM
Re: Problem with hard drive on Sky Q.
Follow the advice in this help article to reset your hard drive;
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Message posted on 23 Aug 2024 10:58 AM
Please advise
Hi @RAB171
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
