Discussion topic: Problem with Watch from Start
This message was authored by: Sue349
I've just had full fibre installed and I now don't have the option to 'watch from start'. I've rebooted my box but it's still not giving me the option to 'watch from start'
Re: Problem with Watch from Start
Did you change the Q's network settings for the new router?
Hi @Sue349
If you have the white Sky Max fibre router then you need to connect your Q box as if it is a 3rd party router.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd partybroadband (non Sky or Sky Max router ) ,  then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
