Discussion topic: Problem with HDMI on Sky Q
Message posted on 24 Aug 2024 09:42 AM
I watch a recording on my TV from Sky Q all working fine. Got up to watch news this morning and TV displaying a blue screen with message saying screen does not support HDCP
HDMI cable has not been touch nor has TV or Q box
Message posted on 24 Aug 2024 10:42 AM
Re: Problem with HDMI on Sky Q
Hi @Petula
Completely remove the HDMI cable at both ends and then refit it ensuring that both ends are fully located.
Message posted on 24 Aug 2024 11:15 AM
Hi @Petula You may have to reboot your TV and Sky Q box.
Message posted on 24 Aug 2024 11:17 AM
I've done all that including unplugging for 30 mins re-inserting cable etc
Message posted on 24 Aug 2024 11:22 AM
How long is the cable? Is it Sky supplied one?
Message posted on 24 Aug 2024 11:30 AM
Yes it's the original cable that came with the Q box I have changed nothing
Message posted on 24 Aug 2024 11:31 AM
Strange. Do you have another cable to try?
Message posted on 24 Aug 2024 11:46 AM
Have you tried a different HDMI socket on the TV? Sounds like it could be a problem at either end.
Message posted on 24 Aug 2024 11:47 AM
No I've never needed one but I will try a different socket and if that doesn't work a different cable.. thank you
Message posted on 24 Aug 2024 01:51 PM
And don't spend more than about a fiver on a cable. Tenner if it's 2m long maybe.
Message posted on 24 Aug 2024 05:13 PM
No im going to need to buy one so stuck until then. I've tried a different pot but it still says the same thing but the box seems to be working with all the lights on etc so not sure what has happened or why as I have touched it until now
Message posted on 25 Aug 2024 09:51 AM
Thank you tried it but nope, no joy
Message posted on 25 Aug 2024 09:57 AM
Message posted on 25 Aug 2024 11:46 AM
Yes tried all that thanks and no, I'm a one TV household 😁
I will have to wait for a new cable to come then try that as my last resort I suppose
Message posted on 26 Aug 2024 05:37 AM
Cable came with Q box
