Discussion topic: Problem replacing Sky Q box
Message posted on 28 Oct 2025 09:19 AM
My box goes yellow overnight, and won't start. Every time I want to use it I have to turn it off and restart it, it will then work for a length of time and if in middle of a recording the screen will go blank and say there is a technical fault. So u have to restart box again. When it's locked in its standby mode it won't record anything that you have scheduled
New box was ordered last week but due to "account issues" it might be few days. What does that MEAN?. If I go to MySky it says I have an order in but if I press tracking it then says no order. Spent 30 mins phoning them today and even Sky can't track my ne box. They are suppose to ring me back tomorrow at 11 as they need 24 hours to get back into account. Let's see if that happens????
What's happening SKY you got warehousing problems
Message posted on 28 Oct 2025 11:15 AM
Re: Problem replacing Sky Q box
@Co1insmith wrote:What's happening SKY you got warehousing problems
Us other customers here can't answer that... You aren't contacting Sky posting here.
Message posted on 28 Oct 2025 04:36 PM
@Co1insmith is it going yellow or red overnight ? If its red it could be the stanby settings need changing
Have a look at the link below
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 28 Oct 2025 07:27 PM
Stays on orange but the only way to get it to work is turn it off and restart
Message posted on 28 Oct 2025 07:51 PM
@Co1insmith did you look at the link I posted and have tyou tried changing the standby settings to none to see if it helps
