1
This discussion topic has been answered Discussion topic: Poor signal ?
This message was authored by: Adders2
Poor signal ?
Channel 404 unwatchable and it says due to poor satellite signal yet every single other channel is perfect?
Re: Poor signal ?
@Adders2
It's not uncommon. If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Re: Poor signal ?
@Adders2
