Discussion topic: Please insert Viewing Card chip facing up
This message was authored by: Jewel
Re: Please insert Viewing Card chip facing up
Hi @Jewel
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Avatar for Jewel
From your instructions I have followed step by step. When click on SYSTEM INFO - it shows - Set up after clicking on that Please Insert the Viewing Card chip facing up. But Viewing Card already in the box and right way.
Are you sure it is correctly fully engaged @Jewel
There should not be enough of the card protruding to grip it if it is in correctly
