Discussion topic: PlayStation nightmare
Message posted on 05 Aug 2025 06:58 PM
Since had Qbox cannot use PlayStation
Message posted on 05 Aug 2025 09:01 PM
Re: PlayStation nightmare
@Carolfraipont wrote:Since had Qbox cannot use PlayStation
Why not?
They aren't connected in any way and should be plugged into separate HDMI Ports on your TV.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 06 Aug 2025 06:19 PM
What exactly is happening with your PlayStation?
I don’t work for Sky.
If I have helped then please leave a like.
Message posted on 07 Aug 2025 03:46 PM
I bet turning the PS on turns the TV on which then wakes up the Sky box via HDMI-CEC and switches to its input.
Should be able to just manually change the hdmi input on the TV back to the PS.
