Discussion topic: Pixelation on various channels
Message posted on 26 Aug 2025 08:27 PM
I have been suffering with pixelation and stuttering for a while now. Seems to affect a range of channels. Signal strength etc. are all good with green ticks. Do I need to get an engineer?
Message posted on 26 Aug 2025 08:32 PM - last edited: 26 Aug 2025 08:34 PM
Re: Pixelation on various channels
hi @Glenn46
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
BTW The signal quality indicator on SKY Q is slightly misleading as it doesn't show the status of the current channel but shows a fixed transponder set in an engineer's menu
Message posted on 31 Aug 2025 04:56 PM
Most likely dish alignment. Not all channels are on the same satellite hence why some pixilate and some don't.
Message posted on 31 Aug 2025 05:14 PM
Not all channels are on the same frequency.
And the signal test only uses one specific frequency.
