Discussion topic: Pixelated imagery with Sky Q
This message was authored by: Ciaranfitz48
Hoping someone could help me. We had a really bad storm the other day which caused the signal to act up. It didn't show a message saying no signal, but the images would be distorted or lagging. The following day was fine but now it's been like this for the last couple of days even in good weather conditions. Signal strength is at 60 and signal quality is at 90 so I'm not sure what could be causing this. Coming to the conclusion that there might be an issue with the cables. Anyone had a similar issue before? Any advice would be greatly appreciated.
Re: Pixelated imagery with Sky Q
Hi Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Avatar for Ciaranfitz48
@Quoman7 Tried that and still not working. Not sure what else I can do.
Call Sky to log a fault perhaps?   You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Cheers I'll have to ring on Monday as I can't think of what else could be causing this.
@Ciaranfitz48  If your in the UK they are open until 11pm today & open on Sundays also.
I'm in ROI so will have to wait until Monday sadly. Thanks again.
This message was authored by: NigelMay
We have just received a new box and having the same issue, with the previous box was perfect.
could it be a setup issue?
