Discussion topic: Pink frozen screen when using Ethernet
Message posted on 26 Mar 2023 11:49 PM
Hi I'm trying to use Ethernet where possible for my SKY mini boxes
All is good apart from the last box that just seems to throw a fit as soon as I plug the Ethernet cable into the back - it works for about 20 seconds and then freezes with a pink screen and then needs a power cycle to get back online with the Ethernet removed.
I've swapped the mini box for another - same problem
same on DHCP
I've set all of the minis and SKY Q to fixed IP at xxx.xxx.x.180-185 - same problem
latest firmware updates
i just don't get why the Ethernet connection sends it loopy
im going to plug my lap top in to the same Ethernet tomorrow to make sure the cable and connection to the router is good but I'm pretty sure it will be
baffled 😞
Message posted on 27 Mar 2023 08:54 AM - last edited: 27 Mar 2023 08:56 AM
Re: Pink frozen screen when using Ethernet
Ok that is properly weird
You don't need fixed IPs (presumably that range you used is outside your DHCP scope?) but shouldn't matter either.
Message posted on 27 Mar 2023 09:14 AM
same on DHCP
baffled 😞
Hi @CCTV+Nerd
Unless your main Q box is also on Ethernet then you need to be on Sky Broadband to Ethernet connect minis. Unless that is you are connecting them to your main Q box by Ethernet.
Message posted on 27 Mar 2023 09:29 AM
Have seen pink screens occur on devices when an hdmi or ethernet cable is faulty or wired incorrectly.
Have you tried swapping the ethernet cable over.
Message posted on 27 Mar 2023 05:16 PM
@oldfella Main SKY Q box is on the same network connected to a Sky Q router via Ethernet
Message posted on 27 Mar 2023 05:20 PM
@ChodleyDHCP does cover the full range but nowhere near enough devices to get anywhere near that IP address.
I thought it might be an IP duplicate so changed to fixed at 180 for main sky Q and then all of the following SKY minis at 181-184
like you say I don't think it's that but still baffled lol
note if using Wi-Fi the box sits on the same address and works quite happily
Message posted on 27 Mar 2023 05:24 PM
@lettice A friend of mine who is a sky engineer said it may be a dodgy HDMI lead but I was thinking that with it working fine over Wi-Fi and then failing as soon as it's moved to Ethernet it didnt add up
my next test is a long bit of cat 5 from the router to the sky mini to test the Ethernet but the cable tested ok using my tester so I'm not expecting it to be that
Message posted on 27 Mar 2023 10:01 PM
Tested the same cat 6 that is going into my sky mini with my lap top with Wi-Fi switched off and it jumped straight onto the network no issues so I'm even more baffled as to why the box crashes
