Discussion topic: Picture keeps freezing
Message posted on 23 Jul 2024 08:44 PM
Had Sky Q for over a year now and for some reason when I'm streaming tv the picture keeps freezing. Its getting really annoying now. Tried "help" on the home page but it wouldn't load, tried the rest of of the icons and this is the only one that would load. The area I'm in isn't covered by EE and that's who Sky use. Could this be part of the problem?
Message posted on 23 Jul 2024 08:47 PM
Re: Picture keeps freezing
