Discussion topic: Picture keeps breaking ip
This message was authored by: Qsw1953
struggling to watch sky as the picture keeps breaking up . Thought it was the bad weather but now it's constant even when no problem with weather . Anyone else got this or what have you done to resolve if it can be resolved .
Re: Picture keeps breaking ip
@Qsw1953
Any message coming up on your screen? It coukd be your dish is out of alignment which would need an engineer to check.
Avatar for Qsw1953
No messages . Seems worse also on itv .
@Qsw1953
Also check a cable on the back of your box hasn't worked loose.
Avatar for Qsw1953
Cleaned the dish . Reset box and still have same issue .
Avatar for Qsw1953
No message on tv just picture breakup
