Discussion topic: Picture is pixelated
Message posted on 03 Nov 2023 07:52 PM
Pixilation loss of sound
Message posted on 03 Nov 2023 08:00 PM
Re: Picture is pixelated
Hi @Davyho
I have removed your other posts on this topic as it is not necessary to raise multiple threads on the same issue.
As regards pixelation and loss of sound have you tried rebooting your Q box?
If the issue continues best to contact Sky directly for an Engineer
Message posted on 03 Nov 2023 08:33 PM
Yes I've rebooted no change rang for an engineer and the first date they can offer is 13/11 - 11 days without tv!
Message posted on 03 Nov 2023 08:36 PM
Hi @Davyho
If you can get into Settings you could try a Reset Settings in the Q box hidden menu.
