Discussion topic: Pay for cinema. It says upgrade. Its happened before and was solved via remote control
This message was authored by: Dale2222
Message posted on 04 May 2024 04:03 PM
Pay for cinema and it says upgrade. It's happened before and was solved via remote control. I can't remember how we did it last time. Please briefly explain how to do it.
Find out more
Message posted on 04 May 2024 04:57 PM
Re: Pay for cinema. It says upgrade. Its happened before and was solved via remote control
hi @Dale2222
May I suggest you try re-freshing the card
Main Menu -> Settings -> System Info scroll across to the viewing card & click on 'setup'
Then click on the button (the whole message) which ends 'Use this option to trigger a callback'
This isn't a call back as such but initiates a refresh of the viewing card - be aware it may take some time to have any effect
