Discussion topic: Paramount +
Message posted on 19 Dec 2023 03:38 PM
Paramount +
Can get paramount+ on my main box but not on my mini boxes,have upgraded the software but no luck,any ideas
Message posted on 19 Dec 2023 05:13 PM
Re: Paramount +
@andyblyhe if you mean the app is not showing
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow on your mini box
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 19 Dec 2023 07:03 PM
Re: Paramount +
Didn't work,I get the paramount logo up but that's it 🙄
