Discussion topic: Paramount+
Message posted on 04 Oct 2023 02:14 PM
Paramount+
Every time I watch a Paramount + programme it buffers around every 15 seconds and dims brightness, I have updated my system via sky but it still keeps doing it. Please help it is very frustrating.
Message posted on 04 Oct 2023 03:56 PM
Re: Paramount+
Hi @dickeym
