Discussion topic: Paramount plus
Message posted on 23 Aug 2023 04:39 PM
Paramount plus
Hi my husband added films so we can get PARAMOUNT PLUS we can get it on our TV but i wanted to add this to my samsung tablet,
I have used the sky.comparamountplus-activate nothing it just says that im already signed in on your TV
All want to do is ger PP on my tablet has anyone had thks problem as well?
Message posted on 23 Aug 2023 04:48 PM - last edited: 23 Aug 2023 04:49 PM
Re: Paramount plus
hi @queennutty if you have already gone through the activation to get it on your TV then you should have been prompted to set up Credentials (Email & Password) for Paramount + which could (& should) be different to your SKY login
You should be able to use the email/password set up during the initial activation to log in to any device with the app - I do so on my computer / Firestick and tablet
Message posted on 23 Aug 2023 04:49 PM
Re: Paramount plus
You should have set up a login when you first created the account and activated the sky link. Just log in to P+ with that. Don't try to activate again.
