Discussion topic: Paramount plus not working on second sky q box
This message was authored by: Shaggy
I have updated the software
Turned off numerous times and says I have got access and to open app.. It then takes to a screen with
Get paramount plus or single in.
Does not allow me to do either
Re: Paramount plus not working on second sky q box
Hi @Shaggy
You say you have updated the Software.   Have you also checked the the Software version is the same on all Q boxes?
If it is
Try a Reset Settings in the main Q box hidden menu.
Once the main Q box is back up and running after the reset Rebbot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
