Discussion topic: Paramount + issues
Message posted on 17 Aug 2025 08:12 PM
Paramount + issues
I get the following error message when trying to view paramount+ Oops! Sorry due to licencing restrictions this video isn't available in your location error code 3304
Message posted on 21 Aug 2025 08:51 PM
Re: Paramount + issues
I have this message also. Have you resolved the issue ?
Message posted on 21 Aug 2025 09:12 PM
Perhaps I may suggest you try a power down restart of your Router & then your SKY Q box(es) :
Unplug or switch off at mains your router, re-apply power & then wait for it to restart & connect back to the internet
Then on your main SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Once the main box is restarted do the same power down on each of the mini boxes (if needed)
Message posted on 21 Aug 2025 10:16 PM
No not yet and only generic non commital answers from Paramount
Message posted on 21 Aug 2025 10:19 PM
Thank you but all tried with no joy
Paramount not helpful and non commital
