Discussion topic: Paramount Plus programmes won’t play
This message was authored by: Zooropean
Hi. My Paramount Plus app will not properly work on the Sky Q box.
i can succesfully log in, choose a profile and browse the programmes, but when I try and watch an episode (or film) the screen goes black with a perpetually spinning white wheel.
This has persisted for a few months now, is the same on all profiles and I have tried reboots and restarts. The app works fine on other devices, such as iPhones, iPad and Android TV.
Any help much appreciated.
Re: Paramount Plus programmes won’t play
Hi @Zooropean
