Discussion topic: Pairing remote to sky mini box
Message posted on 23 Oct 2025 10:40 AM
I am trying to pair remote to sky mini box.
tv light is green.when I press 1and3 light flashes on remote then nothing?
Message posted on 23 Oct 2025 11:40 AM
Re: Pairing remote to sky mini box
hi @Glovers1
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then as you have tried, press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
