Discussion topic: Pairing TCL 55P8L-UK
Message posted on 26 Aug 2026 04:27 PM
I recently bought a new TCL TV which isn't listed on the their pairing list. It pairs using a couple of the number options that will allow me to adjust the volume but that's about it. I've tried various other manufacturers as mentioned here and elsewhere but I can't get any further.
The other weird thing is that when I switch the sky q box on the TV doesn't come on, I've checked the settings and it should but it doesn't.
Will I have to live with the torment of having to use two remote controls or is there an easy fix that I'm missing?
Message posted on 26 Aug 2026 04:29 PM - last edited: 26 Aug 2026 04:30 PM
Re: Pairing TCL 55P8L-UK
@henningn wrote:... that will allow me to adjust the volume but that's about it
What are you expecting to control as that's about it anyway... (Volume up/down and power)
Ensure the Sky box and TV have their HDMI CEC settings on. When you hit the Sky/Home button then the Sky box will attempt to send a power on signal over the HDMI when the TV is in standby.
