Discussion topic: Package states HD & Ultra HD but it's only HD
This message was authored by: Jamma+Monkey
Hiya!
I'm so confused... Looking into savings atm so thought I'd check out the whole netflix situation and maybe move it to sky. I'd want the premium netflix so I know I'd need to have ultra hd pack with sky. My account clearly shows I have HD & Ultra HD pack (pic below).... But I can't watch anything in ultra hd. If I try to download a show in ultra hd it says I don't have the subscription and need to upgrade - buy my account says I do have ultra hd! Anyone else had this? Take it I still need to add ultra hd at £4 per month (after the promo period)?
Re: Package states HD & Ultra HD but it's only HD
Hi @Jamma+Monkey
You also need to check out which Q box you have .
The original 1 TB Q box is not UHD capable.
Also some of the UHD boxes do not do UHD/HDR.
see following link
https://www.sky.com/help/articles/sky-software-updates
Avatar for Jamma+Monkey
It's the 2tb uhd box, so should be all good! I've also checked all video settings etc are correct. I rang sky and the guy was useless... Said maybe I don't have an ultra hd tv lol. I was like, well I 100% do! 😂🤦🏼‍♂️  Eventually he looked at account and said I don't have ultra hd (even though in My sky it says I do) 🤷🏼‍♂️
Hi @Jamma+Monkey
You earlier mentioned a promo period.
Maybe this is the issue
