3
This discussion topic has been answered Discussion topic: PFedup8k
This message was authored by: Crissy11
PFedup8k
Qbox got wires attached an another box pink wire orange wire two aerials also box for  disk ca not cover wires as just put t v on wall
Re: PFedup8k
Yes: a main Q box cannot operate without 'wires'.  As a minimum it needs a power lead (which might have an external transformer block), a satellite dish feed (usually twin, sometimes single) and an HDMI cable for output to the television set: it may also have an ethernet connection for broadband access, and possibly optical audio out.
The closest thing to Sky television access without wires is either the Glass television set or a smart TV running the Now app with a subscription for that service: these would only need a power supply feed.
Re: PFedup8k
Sorry, not sure what you're asking?
Re: PFedup8k
@Crissy11
I'm with @Chodley Your post is very difficult to understand.
Re: PFedup8k
