Discussion topic: Our satellite dish isn't working
This message was authored by: Kersty2
Due to bad weather last night out satalite has no signal
Re: Our satellite dish isn't working
@Kersty2
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye and could only affect one or two channels). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
