Discussion topic: Our Sky Q box continually needs rebooting
Message posted on 03 Apr 2024 03:09 PM
Sky Q box needs rebooting on start or after changing to NetFlix
Message posted on 03 Apr 2024 03:19 PM
Re: Our Sky Q box continually needs rebooting
Hi @Jandenise
Message posted on 05 Apr 2024 11:24 AM
Many thanks. In fact, after all this, the Sky chap replaced the box as had fault, but I really appreciate your help.
