Discussion topic: Orange light on mine box
Message posted on 02 Nov 2025 08:06 PM
Initially was not receiving internet
pressed button on side of hub box
unplugged sky mini box
start up as normal when plugged back in
orange light now in box
what can I do please
Message posted on 02 Nov 2025 08:15 PM
Re: Orange light on mine box
Hi @Offtoshop
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
