Discussion topic: Nothing works
This message was authored by: Poonshaw
Nothing works
Just moved home, new address correct on MySky, but can't connect to Sky on the tv and
cant access live football on the sky app on my iPad even though it's included in my package
Re: Nothing works
So you booked a home move with Sky?
do you use Q or Stream/Glass? Sounds like the latter as you don't mention a dish?
Avatar for Poonshaw
Re: Nothing works
we get Sky Q via cable. I have booked an engineer for Monday but we have moved from a house to a flat on the same development so all the connections and systems are the same. Our neighbour in the block gets Sky. We should be able to plug in and go.
Re: Nothing works
@Poonshaw
I think you mean you now have a communal dish shared by all the flats rather than your own dish.
You may need a certain level of engineer who will need access to wherever the communal dish is - and permission from your landlord or building management company.
Re: Nothing works
Long shot, if you've moved from a personal dish to a communal one then you need to change the LNB settings on the Q:
Press Home on your Sky Q remote
Go down and highlight Settings
Press 0 0 1 on the remote
Press Enter/Select
Select LNB Type
Change the setting from Wideband to SCR
(This is assuming no engineer changes are required at the communal end)
