Discussion topic: Not working
This message was authored by: -dips-
Not working
Sky comes up on screen but remote won't let you connect. Normal buttons like 3 are switching it off and 1turns up sound but that's all it will do.
Re: Not working
@-dips- Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
