Discussion topic: Not working
Message posted on 22 Feb 2025 11:42 PM
Not working
About 2weeks ago we had a really bad storm which seems to have moved my dish and since then my tv isn't working. It didn't bother me too much as I normally let the kids watch Disney app on main tv and could still watch sky on my phone and tablet. But now it won't play the apps either so has obviously became an issue. We have tried everything but moving the dish as I didn't want to damage it.
Message posted on 23 Feb 2025 05:40 AM
Re: Not working
Firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
3 - due to the storms there’s still likely to be a significant delay in getting an appointment so it may be quicker to contact a local satellite company but that would be at your own expense.
