Discussion topic: Not turning on
This message was authored by: Peg10
Not turning on
3 times now the Sky Q box unresponsive.  Unplug wait then plug back in and wait again and fingers crossed works.  Once it showed the tv guide, selected a program then the screen went blue.
Re: Not turning on
Hi @Peg10
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Failing this,
