Discussion topic: Not network connecting to sky q
Message posted on 11 Nov 2023 10:33 AM
No internet connection to sky q box
Message posted on 11 Nov 2023 10:41 AM
Re: Not network connecting to sky q
Hi @Sumindra
Have you carried out Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
