Discussion topic: Not getting bbc or itv
Message posted on 18 Dec 2023 07:39 PM
Not getting itv or bbc says no signal but other channels are still showing
Message posted on 18 Dec 2023 07:53 PM
Re: Not getting bbc or itv
@Shaun29
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. After that look at the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
