Discussion topic: No voice control on replacement sky q remote.
This message was authored by: MikeGreg
I have just received a free sky q remote replacement and it hasn't got voice control. Is it normal practice to send out the basic version.
Re: No voice control on replacement sky q remote.
Hi @MikeGreg the old remote version had the voice button on the right edge of the remote, the replacement version should have a blue voice control button on the face of the remote in the centre.
hi @MikeGreg
In addition to what @Quoman7  says about some older remotes having a side button for voice the remote must be paired  to the box (via bluetooth) to use voice control
If you need to,  try a reset of your remote :
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
