Discussion topic: No sky tv
This message was authored by: Kellylk81
No sky tv
Can u tell me y my sky tv isn't working plz
Is there a problem in the area
This message was authored by: Ellie_TV
Re: No sky tv
In what way is it not working? Are there any error messages on screen?
Avatar for Kellylk81
Level 0 icon
Re: No sky tv
On the screen it is saying currently affected by a problem with your satellite signal?
Everything was working last when I turned it off to go bed but this morning I've got this on  y screen
Re: No sky tv
@Kellylk81
Satellite signals are not area based. It's either the whole country down or just your set up.
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels and
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
