Discussion topic: No sky cinema
This message was authored by: spyro123
No sky cinema
Again I have no sky cinema! Been about a month, this is the 3rd or 4th time it's gone down. It now says no satellite signal. Any help would be appreciated, as I'm so fed up with paying for a service that I'm having so many problems with. Thanks
Re: No sky cinema
@spyro123
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
