Discussion topic: No signal
Message posted on 08 Mar 2026 01:25 PM
No signal
I am having issues with no signal unless attached to a WiFi. It's a known area issue spanning 10 days. Our local mp has advised us to contact our provider to get a refund. However, the chatbot is incredibly unhelpful and I cannot see how to get in touch with a proper helpdesk.
any help appreciated
Message posted on 09 Mar 2026 11:04 AM
Re: No signal
No signal or no satellite signal? They are different. Satellite signals are not an area problem. It's either just your set up or the whole of the UK.
”No signal” messages tend to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
When you see a “no satellite signal” error message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling,
▫️very heavy rain or
▫️snow on the dish/LNB
so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 adverse weather can affect the satellite signal and following such events wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
